Activity Forums Adobe After Effects control premiere layer position and scale with an essential graphics made with after effects
  • control premiere layer position and scale with an essential graphics made with after effects
    Posted by Sander De leeuw on November 24, 2018 at 8:32 pm
    Is it possible to use a essential graphics template made in ae to control the scale and position of underlying layers in pr?
    I’m looking to do the following; I have a small visual effect where I draw a circle that comprises the full composition and gradually zooms in and circles a piece of video on a underlying layer. Now I want to repeat this many times with different underlying video clips. So I’ve made the effect into a essential graphics template, and loaded it into premiere. But now I want to make the piece of video in premiere zoom and move like the circle in the template. Is there a way this can be done properly?
    To clarify I’ve added a small test video: https://youtu.be/CVw0oxrvysQ
    In this video you can see the zooming of the template has some easy ease and a bit of work in the speed graph to make the movement a bit more interesting. I can’t figure how I can do this in premiere.
    Also since I’ll be using this particular template for about 40 times it would save me a great deal of work if I could automate the zoom and position change.
    Thanks in advance!
    Mark Doctor replied 7 years, 9 months ago 2 Members · 1 Reply
  • Mark Doctor
    November 26, 2018 at 10:59 am
    Use the nesting in Premiere
    1# sequence: add a cyan circel animation above the original footage track
    2# sequence: Now circel and footage are bound in a nested sequence and scale them together to the corner. Revealing a sheet with text ( I would create that one in Premiere itself)
    Save your project, import it 40 times and replace the footages
