Activity › Forums › Adobe After Effects Expressions › Control Paragraph Text Box Size by an expression
Posted by Detlef Maerz on January 16, 2023 at 10:34 amHi guy, is it possible to to read out or also change paragraph Text Box Size by an expression?
Andrei Popa replied 3 years, 8 months ago 5 Members · 5 Replies -
Manuel Moellmann
January 16, 2023 at 10:47 amit is possible to an extent. its a bit tricky to actually change the paragraph text box but you can surely change its size by expressions.
check out this:
https://creativedojo.net/store/responsive-auto-scale/
Yoan Boisjoli
January 16, 2023 at 8:10 pmIf you wanna learn about it while finding out a possible solution, here’s a link to a well explained video: https://www.youtube.com/watch?v=flnRYVMbMmQ
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Detlef Maerz
January 17, 2023 at 10:09 amBoth interesting tips. Thanks for that, guys! But I am explicitly thinking about the paragraph text. So resize the frame that is created at the beginning of the paragraph text. Maybe its possible with extend script?
Tomas Bumbulevičius
January 17, 2023 at 11:37 amDetlef, it should be possible with extendscript – the question is why/when you want to modify its size?
Andrei Popa
January 17, 2023 at 12:52 pmI think you can use this function.
function setBoxSize(myLayer, boxSize){
var textProp = myLayer("ADBE Text Properties")("ADBE Text Document");
var textDoc = textProp;
textDoc.boxTextSize = boxSize;
textProp.setValue(textDoc)
