Activity Forums AJA Video Systems Control Panel says AJA hardware not installed
  • Control Panel says AJA hardware not installed
    Posted by Scott Bethel on October 18, 2007 at 6:32 pm
    I already searched this and found someone having same problem but the same advice has not helped me.
    2 x 3Ghz Quad-Core Intel Xeon
    FCP Studio 2
    I installed the card, installed software off CD, oops, uninstalled software and installed it again via website download.
    Used Expansion Slot Utility to configure card in slot 3 at 4x
    Still getting same message
    Uninstalled software again and reinstalled – still says AJA hardware or software not installed
    Rinse and repeat
    Rinse and repeat
    Only an insane man keeps the same course of action and expects different results.
    HELP
    Arnie Schlissel replied 18 years, 11 months ago 4 Members · 6 Replies
  • Jeremy Garchow
    October 18, 2007 at 6:59 pm
    Call AJA immediately.
    What version of drivers?
  • Scott Bethel
    October 18, 2007 at 7:06 pm
    4.0
  • Jeremy Garchow
    October 18, 2007 at 7:13 pm
    Yep, call AJA
  • Scott Bethel
    October 18, 2007 at 7:40 pm
    Called them – ran a bunch of “fixes” and it came down to this –
    By installing the drivers from the enclosed CD (V.2) the card “broke” and will not read. Not even uninstall will help. They are overnighting a new card.
    Thanks for your help.
  • Bob Zelin
    October 18, 2007 at 8:56 pm
    #1 my stupid opinon – AJA should stop sending out drivers on CD. You either have an internet connection or TOO BAD. I deal with Disney, Lockheed Martin, etc. that have MAJOR SECURITY – you either have an internet connection to download drivers or YOU DONT GET TO PLAY IN THIS GAME. I feel your pain, but you should NEVER use drivers that come on CD, from anyone, including AJA, ATTO, Blackmagic, AVID software releases, Apple, etc, etc.
    #2. If I was there, the first thing I would have done is RESEAT THE CARD. I have often been in a rush, and not seated the card properly, and it showed “hardware not installed”. Reseat your card.
    Bob Zelin
  • Arnie Schlissel
    October 19, 2007 at 6:08 pm
    [Bob Zelin] “#1 my stupid opinon – AJA should stop sending out drivers on CD. You either have an internet connection or TOO BAD.”
    FWIW, I almost never install drivers off of the cd or DVD that ships with a product. Any product. Scanner, PCI board, turbocharger, anything. The only time I use the driver shipped with a product is if I can’t find one on their website.
    Good manufacturers work to improve their products. With computer peripherals & expansion cards, that often means driver updates. The Kona card (or turbocharger) that you buy could have been boxed up many months ago, and I’d like to think that they’ve been working to upgrade what it does, or how well it plays. Also, the drivers in the box may not be for your version system software. Or who knows?
    I always check to see if there’s a newer or more appropriate driver than the one in the box.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
