Activity › Forums › AJA Video Systems › Control Panel Presets? What Presents?
Posted by Lee Berger on September 27, 2005 at 6:00 pmAnybody else have a problem with the Control Panel forgeting presets? I set them and the next time I boot up they’re gone. Not only that I have to go in and reset the video and audio input/output settings.
Aja Sales department replied 20 years, 11 months ago 4 Members · 8 Replies -
Jeremy Garchow
September 27, 2005 at 6:30 pmThis happens all of the time to me as well.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Lee Berger
September 27, 2005 at 6:34 pmI sent a message to AJA support a few weeks ago and was surprised when there was no reply. They are usually quite responsive. Perhaps this is a major bug they’re wrestling with.
Mike Laur
September 27, 2005 at 7:07 pmSame thing here: genlock settings get switched upon startup.
Mike L
Mike Laur
September 27, 2005 at 7:12 pmSame thing here: genlock settings get switched upon startup.
Mike L
September 28, 2005 at 1:48 pmHi-
Any and all of the Io Control Panel settings, including ProcAmp, can be saved and recalled later. Are you saving the presets as “default” as follows?
Under the “Presets” tab, there are controls for “Load Preset” and “Save Preset As…”. Any preset can also be set as the default, with the “Set Default” button, which once set even retains the settings if the Io is powered down and unplugged!
If you are still having issues, please let us know!
Thank you,
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Lee Berger
September 28, 2005 at 2:07 pmI’ve saved, saved as, saved as default, and even named each preset (Betacam, DVCam). Without fail, the next time I boot up, it’s back to the original presets 1-Factory Preset (default), 2-Factory Preset and so on. Each time I boot up I have to go into the control panel, set the input from SDI to Component, Audio to Analog, Output to Betacam Component, adjust the proc amp, etc. The control panel just will not remember the settings from the previous session.
Jeremy Garchow
September 28, 2005 at 2:17 pmI have the exact same problem. NO matter how many times I save, save as default, whatever, it still reverts back to the factory presets.
September 28, 2005 at 9:21 pmHi-
Thanks for the feedback. I will forward this to our engineers and see if there is an issue they are aware of.
In the meantime, our support department is here to help, via email to support@aja.com, or better yet via phone to +1 (530) 271-3190, 8am-5pm PST.
Thank you,
AJA Video Systems
(800) 251-4224 US
sales@aja.com
