Activity Forums Adobe After Effects Control Opacity Per-Channel? Or mix?
  • Control Opacity Per-Channel? Or mix?
    Posted by Lu Nelson on May 25, 2009 at 7:58 am
    OK, this is really frustrating me and I know there must be a way:
    I have a noise reduction filter that gives good results, but looking at the result channel by channel it is applying too much noise reduction in the red channel. It is a good filter but has no way to control the reduction channel by channel. (It is the Neat Video Pro plugin).
    I’m looking for a way therefore, to mix/composite the result layer with the original layer, applying the blue and green channels at 100% because those results are good, but applying the red channel at 50% because that channel is now overly softened in the result.
    None of the Channel or Color Correction filters seem to have a way to do this, so far as I can gather — am I missing something?
    Thanks in advance,
    LMN
    Roland R. kahlenberg replied 17 years, 4 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    May 25, 2009 at 10:46 am
    Effect>Channel>Shift Channels may be what you’re looking for.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
