Activity › Forums › Apple Final Cut Pro Legacy › Control of BetaSP UVW-1800 using Final Cut Pro
  • Control of BetaSP UVW-1800 using Final Cut Pro
    Posted by Fred Gasser on January 5, 2006 at 8:07 pm
    I need to gain remote control of my Beta Deck through Final Cut Pro. What do I need to do this? Where can I get such items? My technical expertise are lacking. Help!!!
    p.s. how did I do for my first post on CreativeCow?
    Chris Poisson replied 20 years, 8 months ago 6 Members · 6 Replies
  • Steven Gonzales
    January 5, 2006 at 8:17 pm
    I believe most people are using the USA-28X usb to serial adapter from Keyspan. This plus a mini-din 8 cable to 9 pin, and the software drivers from keyspan, should do the trick.
    https://www.keyspan.com/products/usb/USA28x/
    cable source:
    https://www.addenda-elect.com/product.htm under Serial Cable products, mac to RS-422
  • Fred Gasser
    January 5, 2006 at 8:25 pm
    Thanks for the info. This site is great.
  • Kevin Monahan
    January 5, 2006 at 8:39 pm
    You’ll likely need to create a new device control preset in your prefs, though.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Shane Ross
    January 5, 2006 at 8:40 pm
    Good frist post.
    Here is the workflow on how to capture the beta footage routed thru a DV camera or deck:
    https://proapptips.com/tips/article.php?story=20050801043306611
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • David Fortin
    January 5, 2006 at 9:02 pm
    Are you just starting up with FCP and have a lot of BetaSP footage and still shoot BetaSP?
    I purchased the BlackMagic DeckLink SP card and it has worked great for me. Using this I am able to capture 8bit Uncmopressed.
    Unless I’m missing something, if you shoot in BetaSP, I think you’ll want to be capturing it that way and editing in 8bit Uncompressed.
    Text graphics and moving JPEGs are so much clearer when editing on an 8bit Uncompressed timeline.
    I realize it’s more money, but if you’re use to BetaSP quality, I think you’ll find editing on the DV codec to be a let down.
    For what it’s worth. (it may not even be 2 cents)
    David
    Dual 2.5 G5 {OS 10.3.7}
    4.5 GB RAM
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    FCP Production SuiteHD 4.5
    Media Cleaner Pro 6
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
  • Chris Poisson
    January 6, 2006 at 2:42 pm
    I control my 1800 through the RS422 cable from my Kona LH, and previously through the same cable on my Decklink SP. Also remember to set the far left hand button to remote.
    Have a wonderful day.
