Activity Forums Adobe After Effects Control more than two keyframes with expressions
  • Control more than two keyframes with expressions
    Posted by Anna Salamaña on September 10, 2021 at 12:56 pm
    Hello! I’ve been using this forum for a while now and it’s been always very helpful. I just came up with an idea that I’m not sure it’s possible, but I would like to share it in case someone can help me think of a different approach to it, if not guide me on the right path.
    So right now I have a shape layer that has its wide controlled by an expression that compares the length of 3 different text layers and picks the widest one. Additionally to this, I have a 4th text layer that appears for 10 seconds which when it appears I have 4 keyframes to change the length of the shape layer.
    The idea is to have keyframes 1 & 4 be the same, and have the 2nd and 3rd be also the same so 1 transition to 2, and 3 to 4.
    Right now I’ve managed to write it so it either transitions well from one keyframe to the other with a linear expression. But I’d still need to do the second transition.
    The following is the expression I’ve worked with, in bold you’d see I have two linear expressions but I can only have one happen as far as I know. (I think I probably just miss some javascript knowledge to make it happen).
    dropMenu = comp(“WORD BANK”).layer(“ROMANIZATION”).effect(“Feature”)(“Menu”);
    text1A = thisComp.layer(“Dialogue1_target_”).sourceRectAtTime().width;
    text1B= thisComp.layer(“Dialogue1_target_RTL”).sourceRectAtTime().width;
    text2 = thisComp.layer(“English”).sourceRectAtTime().width;
    text3 = thisComp.layer(“Romanization 1”).sourceRectAtTime().width;
    text4 = thisComp.layer(“Literal Translation1”).sourceRectAtTime().width;
    widestA = Math.max(text1A, text2, text3);
    widestB = Math.max(textB, text2, text3);
    widestVar = Math.max(text1A, text2, text3, text4);
    RLPadding = 130;
    x = value[0];
    y = value[1];
    if (dropMenu == 1) {
    if (engWide < engLitWide){
    (linear(time,key(1).time,key(2).time,[x – widestA – RLPadding, y],[x – widestEng – RLPadding, y] && linear(time,key(3).time,key(4).time,[x – widestEng – RLPadding, y],[x – widestA – RLPadding, y]))
    else
    [x- widestA – RLPadding, y];
    } else if (dropMenu == 2) {
    [value[0]- widestA – RLPadding, value[1]];
    } else if (dropMenu == 3) {
    [value[0]- widestB – RLPadding, value[1]];
    The idea would be to do the same in the other else if statements if this is doable.
    Thank you in advance!
    Best,
    Anna
    Anna Salamaña replied 5 years ago 2 Members · 2 Replies
  • Fabrice Leconte
    September 10, 2021 at 2:25 pm
    Hello,
    I think you just need to add “if & else” statements.
    something like:
    if(time < key(3).time){
    linear(time,key(1).time,key(2).time,[x – widestA – RLPadding, y],[x – widestEng – RLPadding, y])
    else{
  • Anna Salamaña
    September 14, 2021 at 12:20 am
    Hey Fabrice,
    That’s it! I tried it out and it works like a charm.
    Thank you so much!!
