Activity Forums Adobe After Effects Expressions Control layer opacity with “Master Null” whilst respecting existing keyframes?
  • Control layer opacity with “Master Null” whilst respecting existing keyframes?
    Posted by Wick Van den belt on September 9, 2016 at 10:04 am
    Hi all!
    I was trying to achieve something, however I haven’t found a good solution for it.
    I have a Pre-comp (Let’s call it “Overlay”), now I would like to control it’s opacity with a checkbox with the master null (e.g. Layer on/off).. -However the layers in the precomp already have opacity keyframes (going from 0 – 50).
    So in the master comp I would like to be able to use the switch to control the on/off for this layer (basically by changing it’s opacity between 0 – 50) but in that scenario the keyframes are no longer respected.
    I have created a null called “UNIVERSAL CONTROLLER” with a checkbox called “” and I use the following expression on the Overlay-layer :
    cb = comp(“Universal Controller Video”).layer(“UNIVERSAL CONTROLLER”).effect(“Overlay”)(“Checkbox”);
    if (cb.value) 100 else 0;
    Is there something I could do with the expression to respect the existing keyframes, or is there a workaround that might do the trick?
    I hope I’ve explained the idea well enough to understand 🙂
    Thanks a lot!
    cb = comp("Universal Controller Video").layer("UNIVERSAL CONTROLLER").effect("Overlay")("Checkbox");
    WickieMedia.net
    Wick Van den belt replied 10 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 9, 2016 at 11:02 am
    Try changing the last line to this:
    if (cb.value) value else 0;
    Dan
  • Wick Van den belt
    September 9, 2016 at 3:22 pm
    That was it!
    Thanks so much, you’re really THE expression guru 🙂
    WickieMedia.net
