Activity Forums Adobe After Effects Control keyframes with marker
  • Control keyframes with marker
    Posted by Henri Yates on June 2, 2021 at 3:20 pm
    Hello,
    I have some keyframe at the end of a comp layer which I will extending very often so I want something which can help move the keyframes around with MARKER so whenever I extend the comp layer to say 20 minutes, I can move the MARKER way to the 19th minute or something.
    Any help or suggestion please?
    Henri Yates replied 5 years, 3 months ago 2 Members · 4 Replies
  • Walter Soyka
    June 2, 2021 at 6:21 pm
    There might be easier/better ways to approach this. Can you share a screenshot or an AEP with the keyframes you’re trying to automate so we can get a better sense of what exactly needs to happen?
  • Henri Yates
    June 3, 2021 at 7:02 am
    Here’s a screenshot please….
  • Walter Soyka
    June 3, 2021 at 2:35 pm
    If you were to precompose that, you could use a protected region to keep your animation together at the end of the clip so you’d only have to drag the end of the comp out.
    When you have a protected region on one comp that’s nested into another, dragging the handles at the beginning or end of the layer does an automatic time stretch instead of a trim — but any protected regions are preserved.
    https://helpx.adobe.com/after-effects/using/responsive-design.html
    Failing that, applying this expression to every keyframed property should have them start their animations at the time of the first marker on the layer, then run straight through:
    try {
    if (time >= thisLayer.marker.key(1).time) {
    thisProperty.valueAtTime(thisProperty.key(1).time + time - thisLayer.marker.key(1).time);
    } else {
    valueAtTime(thisProperty.key(1).time);
    } catch (err) {
    value;
  • Henri Yates
    June 3, 2021 at 5:25 pm
    I will try it out
