Activity Forums Maxon Cinema 4D Control intensity of individual light inside Cloner (grid)
  • Control intensity of individual light inside Cloner (grid)
    Posted by Anders Hattne on June 27, 2017 at 1:27 pm
    Hello!
    I have a feeling this could be solved with my basic skills.. but maybe not..!
    I have a grid of lights in a cloner and want to control the intensity of them with an effector — shader effector maybe but not necessarily. Is that possible?
    Many thanks!
    /Anders
    http://www.ardillamedia.com
    Anders Hattne replied 9 years, 2 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    June 27, 2017 at 5:33 pm
    You can do this by using the Cloner’s blend mode, which, as the name suggests, creates clones that blend between different parameters. In this case you’d add two lights to the cloner: one with a high brightness and one with a low brightness.
    Then you can use effectors with their “modify clone” parameter turned up to create the blend locally.
    Here’s an example file. Note the effect doesn’t show up properly in the viewport, but it does when you render.
    11475_blendlightintensity.c4d.zip
  • Brian Jones
    June 27, 2017 at 11:42 pm
    here’s another example using a shader effector with Color Mode On/Subtract with an inverted falloff
    11476_shadereffectorlights.c4d.zip
  • Anders Hattne
    June 28, 2017 at 8:03 am
    Holy schmoly!
    Thank you very much – those are some interesting solutions!!
    Gonna have a look at this and study the techniques!!
