Activity Forums Adobe After Effects Expressions Control Expression Start
  • Control Expression Start
    Posted by Aaron Esterling on December 20, 2010 at 10:31 pm
    I’m using this great “Bouncy Scale In” expression from mographwiki.net but can’t control when it starts. Currently, it starts at the beginning of the comp regardless of where the layer starts.
    I’ve tried to modify it using a couple methods I’ve found on the forums, but I either break it or it doesn’t do anything. Any help would be appreciated. Thanks!
    k=16; // final scale
    a=5; // how quickly the bounce ends
    b=20; // how many bounces it'll do (that is, the bounce speed)
    x=k*(1-Math.exp(-a*time)*Math.cos(b*time));
    [x,x]
    Gavin Mcdonald replied 14 years, 1 month ago 3 Members · 5 Replies
  • Dan Ebberts
    December 20, 2010 at 10:51 pm
    This is how you’d change it to start at the layer’s in point:
    b=20; // how many bounces it’ll do (that is, the bounce speed)
    t = time-inPoint;
    x=k*(1-Math.exp(-a*t)*Math.cos(b*t));
    [x,x]
    Dan
  • Aaron Esterling
    December 20, 2010 at 10:52 pm
    Thanks for the quick reply, Dan. Works great!
  • Gavin Mcdonald
    August 8, 2012 at 9:55 pm
    What if you want it to reverse at a layer out point?
  • Dan Ebberts
    August 8, 2012 at 10:04 pm
    This should do it:
    t = (time < (inPoint+outPoint)/2) ? time – inPoint : outPoint – time;
    [x,x]
    Dan
  • Gavin Mcdonald
    August 9, 2012 at 2:12 pm
    Thanks Dan,
    It actually looked real weird reverse bouncing. So all I wanted it to do was scale down so I had to duplicate the layer and fade between adjusting the out layers bounces to 1.
    You’re a legend.
