Control Duration of Pre Comp with an Expression
I am creating a lower third for mastering. I am able to set the in and out points with sliders and because they can be variable lengths I have set the middle as a still. I need an expression that would allow me to adjust the duration of this middle section with a slider. I can then link the subsequent versions to this.
Ideally I would use a slider to link each versions ‘stretch’ tool to adjust the length but obviously this is not key frame-able.
Any help would be very much appreciated.
cheers
Andrew
