Activity Forums Adobe After Effects Expressions Control audio volume with expressions
  • Control audio volume with expressions
    Posted by Nick Leigh on December 14, 2010 at 3:21 am
    Can anyone point me to an expression example where an audio layer is controlled by an expression? Basically I would like to control the dB of the audio at certain times and maybe fade it in/out if that is possible too. Thanks for your help.
    Nick
    CS5 Production Suite
    Todd Kopriva replied 15 years, 9 months ago 2 Members · 3 Replies
  • Todd Kopriva
    December 14, 2010 at 6:55 am
    There are some examples here, including a really nifty one by Nathan Gambles that ducks the audio of one layer in response to the audio levels in another layer.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Nick Leigh
    December 15, 2010 at 5:01 pm
    Hey Todd,
    Thank you for that resource. Looking through all of them I can’t find where someone controls the volume of the audio layer. Basically what I want to do it create an expression that will use values from a null layer to know what volume a specfic layer shoudl be at. So I guess what I am asking is what is the code I need to adjust the volume.
    I thought it was something like:
    thisComp.layer(“Audio Layer”).audio.audioLevels
    but it is giving me anything. So how do I access the audio level at any given time? Thanks
    Nick
  • Todd Kopriva
    December 15, 2010 at 5:14 pm
    As I said, the example by Nathan Gambles gives you what you need.
    Don’t use Audio Levels. Use the properties of the Stereo Mixer effect, as Nathan does in his example.
