Activity Forums Adobe After Effects Expressions Control 2D movement on position property with angle control
  • Control 2D movement on position property with angle control
    Posted by Noel Powell on May 26, 2016 at 12:58 pm
    Hi all,
    I thought I’d be able to easily find this one, but I’m not seeing it anywhere. I’m looking for an expression to convert the degree value of an angle control to X and Y movement. Basically, I want to control the direction of the noise (Offset Turbulence property) in a Fractal Noise effect with an angle control to set the direction, and a slider control to set the speed.
    Any help you can give is much appreciated.
    After Effects Templates – digital glitch effects, 80s VHS effects, old film effects, art effects, and more: https://CreationEffects.com
    Noel Powell replied 10 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 26, 2016 at 1:45 pm
    This should work for static controls:
    a = effect(“Angle Control”)(“Angle”);
    spd = effect(“Slider Control”)(“Slider”);
    d = spd*(time-inPoint);
    r = degreesToRadians(a-90);
    x = d*Math.cos(r);
    y = d*Math.sin(r);
    value + [x,y]
    If you need to animate the controls, that’s a whole different story.
    Dan
  • Noel Powell
    May 26, 2016 at 1:54 pm
    Yeah, I assumed it would have to be static. This is very helpful, Dan. Thank you.
