Activity Forums Adobe After Effects Expressions Control 2 keyframes from 2 different layers
  • Control 2 keyframes from 2 different layers
    Posted by Mat Chevitz on September 3, 2010 at 11:41 am
    Hey,
    Here is my case :
    I would like to control the value of 2 different keyframes, from 2 different layers. Is it possible ?
    For example, i would like the 2 keyframes on the left to be the same value which i could control.
    Thx
    Brice
    Dan Ebberts
    replied 16 years ago
    2 Members · 1 Reply
  • Dan Ebberts
    September 3, 2010 at 3:49 pm
    Assuming the keyframes are linear, you could replace the value of the first one of each pair by linking it to a slider on null layer (named “Controls” in this example) with an expression like this:
    v1 = thisComp.layer(“Controls”).effect(“Slider Control”)(“Slider”);
    v2 = key(2).value;
    t1 = key(1).time;
    t2 = key(2).time;
    linear(time,t1,t2,v1,v2)
    This would work for single-dimensional properties like rotation or opacity. For position, I guess you’d use a point control instead of a slider.
    Dan
