Activity Forums Adobe After Effects Contrasting outline against moving backdrop (B&W)
  • Contrasting outline against moving backdrop (B&W)
    Posted by Eric Chard on June 19, 2015 at 8:52 pm
    I’ve got a simple, cartoony animation that is black and white. It starts on a flat white background, then moves to a black background, thru a short gradient.
    Trouble is, the character is simply black lines, so once ‘he’ gets to the black backdrop (space) he’s hard to see. When he’s fully in space, I can just add a small white halo around him, but I’d like the outline to slowly fade it, automagically, in case I have to shift timing, and because down the road I can see that this will be a continuing need for the style of this animation. IOW, I’m going to have to do this repeatedly, it’s not a one-off.
    Now that I’ve typed out the problem, I suspect some sort of blending mode is the way to go, but I’d still appreciate suggestions. THANKS.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Richard Herd replied 10 years, 10 months ago 2 Members · 1 Reply
  • Richard Herd
    June 22, 2015 at 3:18 pm
    [Eric Chard] “blending mode”
    Is my suggestion.
    And there is always rotoscoping!
