Activity Forums Apple Final Cut Pro Legacy contrasting filming formats …
  • contrasting filming formats …
    Posted by Brendan Tyler on June 1, 2009 at 1:39 pm
    hi
    i’ve just imported footage from a wedding i filmed recently
    i used 2 tapes, and have found a profound difference between the footage
    1st tape : appears balanced and even, with a ‘letterbox’ (top & bottom banner) framing, like a movie
    2nd tape : without this framing, appearing to fill the entire screen, with a slightly ‘squashed’ look
    i’ve managed to stretch this out by holding down a corner and literally stretching to a similar rectangle
    i film using a Sony Z1 –
    a) can anyone tell me if there’s an easier way to automatically correct the squashed footage ?
    b) can anyone please tell me how this has happened & what i must have done to make this change
    many thanks
    tyler
    Brendan Tyler replied 17 years, 3 months ago 5 Members · 10 Replies
  • 10 Replies
  • Brendan Tyler
    thanks, i know that
    but i would appreciate some technical advice or insight
  • Steve Eisen
    June 1, 2009 at 1:46 pm
    User error. Know your equipment before shooting important events.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Steve Eisen
    June 1, 2009 at 2:02 pm
    To start, read the manual. Both the camera and FCP. Get some education. You simply can not pick up a camera, press record and call yourself a professional.
    Practice, practice, practice before recording important events.
    Steve Eisen
    Board of Directors
  • Brendan Tyler
    June 1, 2009 at 2:04 pm
    wow !
    thanks again Steve
    not only are you not being helpful
    but you’re now being condescending …
    good for you
  • Shane Ross
    June 1, 2009 at 3:03 pm
    Issue: You have two formats of 16:9…letterboxed 4:3 and anamorphic. What I would do, is make the main format the letterboxed format, and adjust the anamorphic to fit. Otherwise you are blowing up the letterboxed footage by 33% and it looks HORRID.
    Shane
  • Brendan Tyler
    June 1, 2009 at 3:09 pm
    hello Shane
    thanks for that, very helpful
    i will do that in future
    i was just wondering what must of happened between switching the tapes
    as the first one was spot on, and the next was differently formatted
    thanks again
  • Richard Sanchez
    June 1, 2009 at 4:06 pm
    The only thing I can think of, is if you possibly switched it over within the menu of the camera in between tapes. Those menus can be fairly deep so it’s not likely, but certainly not unheard of. Likewise, what FCP settings did you use to capture? Are you editing in HDV, or did you bring it in as DV? It’s entirely possible that the footage on the tapes are fine and match each other correctly, but they were brought into FCP incorrectly.
    I’m not familiar with the Z1’s menus, so unfortunately I can’t tell you specifically in what menu to look.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Brendan Tyler
    June 1, 2009 at 4:45 pm
    hello & thank you very much for that, Richard
    i will take a look at the menu once again
    and pay particular attention to the FCP importing options
    thanks
  • Joey Burnham
    June 1, 2009 at 6:50 pm
    [Shane Ross] “What I would do, is make the main format the letterboxed format, and adjust the anamorphic to fit.”
    I would do the same. Just leave the other footage alone and when you bring in the 16×9 footage (the full frame stuff) you can change the aspect ratio under the motion tab to -33. This will squish down the footage 33% on the y-axis. It should match the other letterboxed footage you have.
    You will need to render this footage eventually, but you should be able to work with it in real time until the final layoff.
    Joey
  • Brendan Tyler
    June 1, 2009 at 6:52 pm
    hello Joey
    many thanks for that
    you guys have been great !
