Activity › Forums › VEGAS Pro › Contour Shuttle Pro
  • John Rofrano
    August 28, 2011 at 3:38 am
    [Mark Krueger] “… can you also tell me if there is a way to identify what all the buttons do or can I customize them? “
    Open the control panel, select the settings file you want to modify, and press any button on the physical Shuttle and the same button will light up on the little shuttle picture in the control panel and the Keystroke setting on the right will tell you what key combination is being used. You can then select a different key for that button to customize it.
    [Mark Krueger] “Also the shuttle dial moves the cursor on the time line but very slowly is there any way to increase the speed? “
    There are two dials. The jog in the center advances frame by frame for precision editing. The outer shuttle ring plays forward and backward a different speeds from slow to very fast.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
Page 2 of 2
