Activity › Forums › Adobe Premiere Pro › Contour pro and Premiere Pro 1.5
  • Contour pro and Premiere Pro 1.5
    Posted by Ron Weber on February 3, 2006 at 6:33 pm
    Anyone use the Contour Pro with Premiere? Having some problems understanding the setup in the control panel. How do you have yours set up? I want to put the labels in for editing.
    Tim Kolb replied 20 years, 7 months ago 3 Members · 3 Replies
  • Tim Bond
    February 3, 2006 at 7:27 pm
    Hi Ron,
    Been using this combo for a while now and love it – everything’s so much quicker. What i did was use the Premiere settings then did a new profile based on it and reprogrammed the non-common buttons to the Pro shortcuts. There’s a quickstart sheet comes with the package or the helpfile on the disk are both quite good at walking you through the setup program. Are you having trouble with anything specific?
    Tim Bond
  • Ron Weber
    February 3, 2006 at 8:39 pm
    I got it used and I don’t think it came with everything. Trying to understand the computer response. I guess it would be the keystroke equal. Guess I need to get the keystroke cheats. I wanted to know what the defaults were for each button. I found out some by just messing with it but didn’t see what others were doing. Any help
  • Tim Kolb
    February 4, 2006 at 4:19 pm
    If you go to the website and download the latest drivers…there should be some default profiles included in there…
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
