Activity Forums Boris FX Continuum only works once!!!
  • Continuum only works once!!!
    Posted by Neil Sinclair on July 15, 2005 at 11:23 am
    This is driving me nuts!! After installing BorisFX Continuum (3.0.4)
    it will allow me to use the filters/generators for only one session
    in FCP 4.5. If I quit FCP, next time I open up I get an error
    message saying I need to re-install. Please can anyone shed light
    on this problem.
    Regards
    Neil
    G5 DP2ghz 10.3.9 QT7
    Neil Sinclair replied 21 years, 2 months ago 2 Members · 2 Replies
  • Scott Fisher
    July 16, 2005 at 3:06 pm
    You should contact their customer support line. It is a known issue and they can get you taken care of even though I didn’t see their hotfix on the website.
    Until you get a hold of a fix, all you have to do is delete your FCP POA cache before launching FCP. It is located in Home folder > Library > Preferences > Final Cut Pro User Data > Final Cut Pro POA Cache. UNfortunately, you will have to do this everytime you launch FCP until you get the fix… but at least you can get your work done.
  • Neil Sinclair
    July 17, 2005 at 8:36 pm
    Thanks advres , this was also a problem in ver 3.0.1
    My reseller in the UK supplied me with a replacement
    version 3.0.4 and it’s still buggy.
    Sorry BorisFX, big thumbs down to you!!
