Activity Forums Adobe After Effects Expressions Continuously Scrolling Image Expression
  • Continuously Scrolling Image Expression
    Posted by Bhenson on August 24, 2006 at 8:26 pm
    I have an image that is wider than my composition and have made an expression that scrolls the image horizontally. Eventually I want the image to loop continuously with the right edge of the first instance of the image always butting up to the left edge of the next instance.
    Right now, the first image will track across the screen as needed followed by the next image. Unfortunately, I don’t know how to make this action continuously loop using only two copies of the original image.
    the end result should be that of a continuously scrolling (almost marquee-like) image.
    Here is the expression being used for the first image:
    xPos= time * -200 ;
    yPos = position[1] ;
    [ xPos , yPos ]
    Any suggestions would be appreciated.
    Bhenson replied 20 years ago 2 Members · 3 Replies
  • Dan Ebberts
    August 24, 2006 at 8:43 pm
    How about only one copy of the image with the Offset effect with this expression for Shift Center To:
    spd = 1.0; //scroll speed (pixels per second)
    [width,height]/2 + time*spd
    Dan
  • Dan Ebberts
    August 24, 2006 at 8:59 pm
    It works, but it should really be like this for a horizontal scroll:
    [width,height]/2 + [time*spd,0]
    Or like this for a vertical scroll:
    [width,height]/2 + [0,time*spd]
    Dan
  • Bhenson
    August 29, 2006 at 2:15 pm
    Thanks for the advice… it solved my problem. I ended up using a slider and linking it to the speed variable.
