Activity Forums Adobe After Effects Continuously Rasterizing Issues
  • Continuously Rasterizing Issues
    Posted by Kristin Crawford on May 23, 2012 at 7:07 pm
    Hello Everyone,
    I have an issue with some of my layers after I turned continuously rasterize on in 5.5.
    Looking back at posts I was able to realize that effects on the layers can distort the layers, and that’s what was happening, so I turned off only the effects to see if that fixed it, only that made it worse, or at least not any better. I then tried to turn off only the continuously rasterize switch and that didn’t fix it either.
    The layers that I’m having trouble with have been animated with the puppet tool, so turning the puppet tool off and the continuously rasterizing off it goes back to normal, but I need the puppet animation.
    Has anyone else ran into this issue? Is there a way to retain the puppet tool mesh and key frames instead of deleting the effect and redoing it all? I don’t think I even need the continuously rasterize on anymore, I just want the puppet effect to come back.
    Thanks in advance for any help!
    Kristin
    Kristin Crawford replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
