Activity › Forums › Adobe After Effects › Continuously rasterize precomps?
Posted by Jiri Fiala on April 6, 2008 at 2:59 pmHello, I have some vector layers in precomp. How do I set the precomp to be continuously rasterized and NOT collapsed? Is it even possible?
Jiri Fiala replied 18 years, 5 months ago 2 Members · 4 Replies -
Darby Edelen
April 7, 2008 at 5:43 am[Jiri Fiala] “Hello, I have some vector layers in precomp. How do I set the precomp to be continuously rasterized and NOT collapsed? Is it even possible?”
It’s the same switch when you’re dealing with pre-comps. So if you enable that switch its both continuously rasterized and collapsed (these two operations can be thought of as the same thing).
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Jiri Fiala
April 7, 2008 at 12:06 pmYes, but I don`t want to collapse the precomp… Coordinates and rotation go nuts when collapsed. I just want the vector art in precomp to be continuously rasterized. There really should be two switches.
Darby Edelen
April 7, 2008 at 3:22 pm[Jiri Fiala] “Coordinates and rotation go nuts when collapsed. I just want the vector art in precomp to be continuously rasterized. There really should be two switches.”
Maybe we can change the way you have your pre-comp set up to fix this. How many layers are in the pre-comp? Are they 2D or 3D? Is the pre-comp layer in the parent comp 2D or 3D?
Coordinates and rotation shouldn’t go ‘nuts,’ they should change in a very predictable manner when you continuously rasterize/collapse transformations.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Jiri Fiala
April 9, 2008 at 9:29 pmDarby, I will look into that tomorrow when I get to job. Thanks for your help!
