Activity › Forums › Adobe After Effects › Continuously Rasterize messing up artwork
  • Continuously Rasterize messing up artwork
    Posted by Guilherme Oliveira on April 16, 2021 at 1:57 pm
    Hello everyone
    I’m facing some issues with the Continuously Rasterize option. Every time I turn it on my artwork gets all messed up, some stuff shapes go missing (characters eyes), some other shapes get out of position (characters arms) and I can’t seem to find a solution.
    Here are a couple of images for reference
    Have you ever experienced this problem? Any fixes?
    Thanks in advance
    Chris Voelz replied 5 years, 5 months ago 2 Members · 3 Replies
  • Chris Voelz
    April 16, 2021 at 3:49 pm
    I don’t know the exact reason behind it but yes, this is normal. I’ve experienced this a number times and it doesn’t always effect every piece equally. Unless you are scaling the artwork you don’t need it enabled.
  • Guilherme Oliveira
    April 16, 2021 at 5:48 pm
    The thing is that I do need to scale the artwork for a specific part of the animation 🙁
  • Chris Voelz
    April 16, 2021 at 9:54 pm
    Did you rig it with DUIK? You can create your artwork at the scale you need it when “zoomed in.” For example I have done some scaling with rigs and created the artwork in a 4k comp, and then scaled them down in AE. That way when you scale it up you aren’t losing fidelity. You could also remove the rig, tick Continuous Raterization, and then re-rig the art. Either way unfortunately requires some re-work.
