Activity Forums Adobe After Effects continuously rasterize is disabling my transfer mode..Help!
  • continuously rasterize is disabling my transfer mode..Help!
    Posted by Robert Paynter on August 18, 2009 at 11:40 pm
    continuously rasterizing/collapse transform is disabling my layers transfer mode and I don’t know why.
    A layer very similar below it is having no problem doing both.
    what’s the catch?
    Simon Tubbs replied 15 years, 3 months ago 3 Members · 3 Replies
  • Robert Paynter
    August 19, 2009 at 2:49 pm
    After adding a mask to the layer it allows me to collapse transforms and use a mode .. Not sure what the reason is but would love and explanation.
  • Alan Parma
    August 20, 2009 at 9:09 am
    hi,
    what kind of layers are these? are these precomps? if they are precomps, you set your transfer modes inside that precomp. hope this helps.
  • Simon Tubbs
    June 6, 2011 at 2:04 pm
    I just worked this out after scratching my head for ages! If you’re working with pre-comps and you have a load of layers within the pre comp set to different transfer modes they all work if you check the continuously rasterize switch. As soon as you add an effect to that pre comp in your main comp – it’s all disabled. Simple as that. Transfer all effects to an adjustment layer or individual layers in your pre-comp and that should solve it.
