Activity Forums Adobe After Effects Expressions Continuous zig zag on a path – like a tank tread
  • Continuous zig zag on a path – like a tank tread
    Posted by Antonio Vicentini on November 3, 2014 at 2:41 am
    Hey guys, how are you?
    Pardon me if there’s already an answer for this, I haven’t found anything similar.
    I’ve created a rectangle shape layer with rounded borders and also added a zig zag parameter on it. I’m trying to rotate those points along the path on a continuous loop, like a tank tread.
    Is there any chance to do it with expressions?
    Any help/advice greatly appreciated. Thank you!
    Alistair David replied 5 years, 4 months ago 3 Members · 4 Replies
  • Dan Ebberts
    November 3, 2014 at 3:58 am
    I can’t think of anything. As far as I know, there’s no way to animate the zig zag attributes in the way that you want.
    Dan
  • Antonio Vicentini
    November 3, 2014 at 4:08 am
    Thanks for the reply, Dan. I’m going to try something else.
    Cheers
  • Antonio Vicentini
    November 4, 2014 at 2:29 am
    Hey Dan,
    A friend of mine made an html solution. I think it might be interesting to share it.
    https://brunoimbrizi.com/_temp/70_antonio/
  • Alistair David
    April 26, 2021 at 11:20 am
    Old tread here (yes thats a pun on thread) ?
    If you need an option with spiky/zig zag look an option would be to use a text animator with text set to a mask path with a ▲ character for the spiky tread. Or alternatively a ■ character with some adjustment to rotation and scale.
    You can see another solution to this here using a dashed line – https://www.youtube.com/watch?v=c90x9E-vtNI
