Activity Forums Adobe Illustrator continuous gradient in illustrator
  • continuous gradient in illustrator
    Posted by Joshua Stanley on August 23, 2005 at 11:15 pm
    OK heres the deal, I have a single object, an outline of a woman standing. I want one of her legs in front of a line and the other leg in back. So I cut delete and pastethe front leg and arrange it so it is the right order, looks sharp. But if I want the outline to have a gradient, I need to apply it to the original object and the leg and the gradient isnt continuous. Is there any way for two seperate object to share the gradient? Thanks in advance.
    Josh
    Joshua Stanley replied 21 years, 1 month ago 2 Members · 2 Replies
  • Seth Taylor
    August 23, 2005 at 11:19 pm
    Select both objects. Then select your gradient tool. Then click and drag the gradient tool by starting below the leg and dragging the gradient tool to where you want the gradient to finish (above her head?)
  • Joshua Stanley
    August 24, 2005 at 8:16 pm
    thanks alot man. That does the trick.
    Josh
