Activity Forums Boris FX Continum 8 complete 3-way color grade does not show color spheres in premiere pro cs5
  • Continum 8 complete 3-way color grade does not show color spheres in premiere pro cs5
    Posted by Mysore Srinivas on February 11, 2012 at 5:20 pm
    When I use the 3-way color grade filter in AE, it works just like described. However, Premiere Pro, I do not see the color spheres. What am I doing wrong?
    Mysore Srinivas replied 14 years, 6 months ago 2 Members · 2 Replies
  • Peter Mcauley
    February 13, 2012 at 2:43 pm
    I haven’t seen this problem on any of the systems that we have here in our labs.
    Unlike AE, the color spheres do not appear as visible objects when you first apply the filter. To make them visible, you need to first twirl open the group that contains them. There are two sets of color spheres, which are used to correct the inside and outside mask regions. If you twirl open the group that is labelled “Inside Lift/Gamma/Gain” the color spheres should appear and operate as expected.
    If this is not working for you, I’d like to suggest that you get in touch with someone in our support department who can assist you in troubleshooting your system to discover why you are not seeing the color spheres. You can reach them at support@borisfx.com.
    Cheers,
    Peter.
  • Mysore Srinivas
    February 15, 2012 at 12:53 am
    Peter, thanks.
    My mistake, I had not clicked on the twirl
