Activity › Forums › Apple Final Cut Pro Legacy › Continued problems connecting Canon GL2 to FCP please HELP
Posted by Sebastian Knight on August 17, 2005 at 7:20 pmI am having ongoing problem connecting my Canon Gl2 to FCP I keep getting error that essentially saying I do not have a camera connected, I have many things I need to capture, over this upcoming weekend please help me.
As always I thank you in advance for your reply to my Post,
Sebastian
Rob Forsythe replied 20 years, 12 months ago 2 Members · 1 Reply -
1 Reply
Rob Forsythe
August 17, 2005 at 7:44 pmThis list contains about everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
14. Important: Quit FCP, then Restart FCP.
15. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729>Then, start again at my “step 1” above.
If you are running FCP 5, please check the following link-
https://docs.info.apple.com/article.html?artnum=301852
If none of these things work, it sounds like you might have a serious hardware problem with either the camera or the Mac.
