Activity Forums Adobe Premiere Pro Continue to Play after using the Next/Previous Edit Shortcut?
  • Continue to Play after using the Next/Previous Edit Shortcut?
    Posted by Alain Durocher on July 10, 2014 at 6:52 pm
    Transitioning to PPro… In a couple of other softwares that I’ve used, you can Play your sequence, hit the “Next Edit” Shortcut (Down key), and have the playhead jump to the next cut in sequence AND it will continue to Play.
    In PPro, it just stops as it jumps to the next edit.
    Is there a particular setting to be tweaked or is it hard-coded as such?
    TIA,
    Alain Durocher
    Octavio Warnock-graham replied 10 years, 11 months ago 2 Members · 1 Reply
  • Octavio Warnock-graham
    October 8, 2015 at 12:38 am
    I’d like to bump this question up. If anyone has an answer to getting PPro to continue playing after pressing ↑or ↓ I’d appreciate the clue.
    Right now it stops after moving to the next/previous edit point.
    Octavio
