Activity Forums DVD Authoring Continious Looping with Compressor?
  • Continious Looping with Compressor?
    Posted by Andrew Thompson on June 26, 2013 at 4:48 pm
    Hello everyone,
    Is it possible to create a DVD that will continuously play in a loop using Compressor? My source is a 7 minute quicktime. Thanks in advance for any info!
    Andrew Thompson replied 13 years, 2 months ago 3 Members · 3 Replies
  • Eric Pautsch
    June 26, 2013 at 7:23 pm
    Compressor doesn’t author a disc, it only encodes
    Make your mpeg from compressor and bring it into DVDSP and set the movies end jump back to itself
  • David Eaks
    June 27, 2013 at 4:54 am
    Hi Andrew,
    Many DVD players have this function, do you have control of what player is used? If not, do you have DVD Studio Pro?
    Eric says-
    “Compressor doesn’t author a disc, it only encodes”
    Sure it does. It’s in the Job Action menu in the inspector. Though it may be extremely limited in customization options. It does Blu-ray as well. The DVD could be set to play on insert and the DVD player set to loop play.
  • Andrew Thompson
    June 27, 2013 at 5:24 pm
    Thanks for the replies fellas. I wound up exporting my sequence from Premiere in MPEG2 then importing into Encore. From there I was able to encode a DVD to loop back to the beginning once it reaches the end.
