Activity › Forums › Adobe Premiere Pro › Content problem (SMI, XML, MP4)
  • Content problem (SMI, XML, MP4)
    Posted by Paul Seelmann on March 22, 2013 at 8:27 pm
    I got some footage from a colleauge who got it from a colleauge etc… which I am supposed to edit..
    for every clip there is an extra folder containing a mp4, a smi, a xml, a bim and a ppn file.
    the mp4 won’t open in any player and I have no Idea what the others are..
    could it be some xdcam footage somebody just dragged on the hard drive without properly “running it through” an importing program??
    anyways I would appreciate your help!
    thanks in advance!
    Paul Seelmann replied 13 years, 6 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    March 23, 2013 at 1:14 am
    Sounds about right, it should be XDCAM. The common workflow is to copy the full contents of the card as those additional files are metadata that some workflows take advantage of.
    In Premiere go to Window > Media Browser, navigate to your footage folder and drag-n-drop from the media browser. This is the proper way to import some card-based footage like XDCAM and AVCHD. If you are coming from Final Cut, it isn’t like a log and transfer workflow.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Jeff Greenberg
    March 27, 2013 at 11:39 am
    Paul, that sounds like exactly what someone did – grab all the files from an XDCam volume.
    If they don’t give you the folder structure exactly like it was on the card?
    Yeah, that’s a problem. You can’t play the MP4 back “in any player” because you don’t have licenses for the XDCam codec for QuickTime (I’m just picking QuickTime as an example.)
    VLC player *should* play it.
    In CS6 Bridge should play it.
    And you should try the MP4 in Adobe Premiere Pro – it may be fine there.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Paul Seelmann
    March 27, 2013 at 6:27 pm
    it does play in premiere (but not in any other player),
    thank you for your help, guys!
    aprrecciate it!
