Activity Forums DaVinci Resolve Consumer monitor recommendations
  • Consumer monitor recommendations
    Posted by Zak Ray on May 31, 2012 at 8:38 pm
    Hi all,
    So I’m on the lookout for a decent, small (max 42″, ideally something I could use on my desk next to the computer monitors), and sub-$1000 consumer monitor that I could calibrate to Rec 709 for basic, non-broadcast, non-theatrical use. Been looking at Panasonic plasmas, but they’re all a pretty big size (and most come with a price tag to match). Anyone suggestions? Using an Intensity card FYI.
    Thanks much!
    Harrison Schaaf replied 13 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Richard Cooper
    June 2, 2012 at 5:43 am
    You can get a 42″ Panasonic plasma for well under $1000 and have plenty left over for a calibration. (about $300)
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Zak Ray
    June 2, 2012 at 6:12 am
    Thanks, Richard. Any specific models you know to perform well? I had some recommendations, but they were all over $1000 (not to mention included 3D capabilities, which I have no need of).
    Re: calibration, I’m mostly doing web work and mostly just need something reliable and consistent. Do I need to invest in something like an X-rite, or can I get by on ol’ fashioned color bars?
    Thanks much,
    -Zak
  • Richard Cooper
    June 2, 2012 at 5:36 pm
    I would get what you can afford as long as it is a Panasonic. If you want consumer then get a basic model you don’t need the 3d stuff with all the bells and whistles. Just a basic Panasonic display like this one:
    https://m.bestbuy.com/m/e/product/detail.jsp?skuId=4841493&pid=1218541224061
    As for calibration hire a professional. Best buy has the geek squad and will come to your studio and calibrate the monitor for you to REC 709 specs. Best $300 you will spend. This is of course assuming that you already have a proper i/o card from Aja, Black Magic or Matrox. Connecting via a graphics card is a wast of your money.
    Just to clarify, this not the best option but rather the best option within your budget.
    If you can afford it, I would suggest a real broadcast monitor like the Flanders….
    Best of luck!
    Richard Cooper
    Anchorage, Alaska
  • Zak Ray
    June 2, 2012 at 6:02 pm
    Hm… was hoping for something a bit smaller, but I suppose I can rearrange the space to accommodate a 42″ or 50″.
    I’m using a Blackmagic Intensity. Would indeed go for a FSI or Dreamcolor if I could afford it, but alas, not in the cards at the moment.
  • Richard Cooper
    June 2, 2012 at 6:43 pm
    I know. It would be great if they made the panny plasmas in smaller sizes. But I believe the 42″ is as small as they get. I mounted my 55″ on the wall above my edit suite and clone ts (and me) love it! Will be upgrading to a 65″ soon.
    Richard Cooper
    Anchorage, Alaska
  • William Edwards
    June 5, 2012 at 4:27 pm
    I was under the impression though that Plasma didn’t come standard with the SDI hookups. That is a separate piece that you need to purchase, at $1,000. How are you intending to hook it up to your system?
  • Richard Cooper
    June 5, 2012 at 4:46 pm
    Black Magic intensity card has HDMI
    No need for HD/SDI
    Richard Cooper
    Anchorage, Alaska
  • William Edwards
    June 5, 2012 at 7:33 pm
    sdi > displayport > hdmi ?
  • Harrison Schaaf
    January 31, 2013 at 3:15 pm
    I appreciate this suggestion a lot, Richard.
    However, seeing as I am setting up an editing suite in Beijing, where there is no geek squad, do you think that using the X-Rite i1 Display calibrator would be a viable solution?
    I’m assuming the difference is that I would end up creating a display profile in my system preferences, rather than having the monitor itself calibrated. What are your thoughts?
    I’m pushing for the FSI, but budget remains an issue.
