Activity Forums Maxon Cinema 4D Constraint objects problem – Animating characters with hats etc
  • Constraint objects problem – Animating characters with hats etc
    Posted by Aaron Harkenin on December 2, 2014 at 10:40 pm
    Hi everyone.
    I’ve read through internet a lot about constraints and PSR constraints and all the other things but since i’m a dummy, i cannot use them effectivly.
    Forexample, i have a character with a hat. I PSR the hat on the head joint and when i animate my character, the hat rotates and navigates somewhere else. The same with the objects character suppose to hold. When i turn characters, the objects either rotate.
    Is there any tutorial for dummies which explains how this constraints work , why they are different (like PSR or Parent or Clamp etc) and which one is ideal for which situations.
    Thank you
    Aaron Harkenin replied 11 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
