Activity › Forums › Adobe After Effects › Constraining one side while moving another.
Posted by Bob Ruhe on June 24, 2013 at 9:34 pmNewbie question I’m sure. I create a rectangle in AE. I want the left side to be locked into place while moving the right side. How to best do this?
Any help is appreciated. And please forgive me for such a rookie question.
Eric Chard replied 13 years, 1 month ago 3 Members · 5 Replies -
John Cuevas
June 24, 2013 at 10:29 pmI’m going to assume you used the rectangle/shape tool to create your rectangle. There is probably a better method for doing this, but here is one method. Use the Pan/Anchor Point tool(Y) to move the anchor point to the side you want to be stationary. You can actually move past that side. Now press scale(S) and, unlock the scales from one another and scale up/down and rectangle will move from the anchor point side.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Bob Ruhe
June 25, 2013 at 12:01 amThank you for the fast reply. I did use the rectangle tool – and as you suggested, and I have tried moving the anchor point but I still get some “creep” in the side I want to keep stationary. Playing with the anchor point still results in movement – but I have to think there’s a way to lock it in place. A coworker suggested using a line instead, but I also have to think I can get the result I want somehow with the rectangle tool. Can’t imagine something like this isn’t possible in AE.
Eric Chard
June 25, 2013 at 5:45 amA coworker shared this tip the other day, amazing how useful it is:
The problem is you haven’t nailed the left side perfectly. To snap the Anchor Point while using the Pan Behind tool, hold down the ctrl key.
TMK it won’t snap to an EDGE, but it will snap to a corner.
(I think it would be GREAT if we could just grab a SIDE instead of all this futzing around.)
“Putting the HARM in ‘harmonica’ since 2005.”
Bob Ruhe
June 25, 2013 at 6:02 amThat’s it! Thanks so much. I was going crazy with this one. I very much appreciate your help!
Eric Chard
June 29, 2013 at 8:45 pmTip sharing is Good.
I just worked with a bunch of great AE operators and everybody was very generous with supplying knowledge. Pass it forward.
