Activity Forums Maxon Cinema 4D Constrain complex object to rigged object
  • Constrain complex object to rigged object
    Posted by Dean Chapman on February 12, 2013 at 1:18 am
    I have a little rig…basically some wires (cylinders) connecting to circuits (boxes). I have this rigged with about a dozen joints. Now, I’d like to constrain a complex object to one of those circuits (boxes). I don’t want to bind this complex object to the rest of the rig….because it’s got too much geometry, displacement & mograph going on. I’d just like the complex object to follow the axis of one of the boxes. I tried using a constraint tag, constraining the complex object to one of the boxes….but this does not work with the rig’s movement…..it ignores the effect of the joints.
    Thanks for any help on this.
    -dean
    Adam Trachtenberg replied 13 years, 7 months ago 2 Members · 4 Replies
  • Dean Chapman
    February 12, 2013 at 1:24 am
    never mind….argh…not enough sleep.
    just gotta drop it under the object as a child. geez.
    -d
  • Dean Chapman
    February 12, 2013 at 1:25 am
    No….wait, i knew i tried that.
    Ya, that still ignores any animation provided by the joints.
    My question still stands 🙂
    -d
  • Dean Chapman
    February 12, 2013 at 1:35 am
    Ok, figured out one way…
    create null, add a constraint tag to that…..use one of the joints as the target, drop complex object into null….offset complex object if necessary.
    -d
  • Adam Trachtenberg
    February 12, 2013 at 3:07 am
    Instead of dropping the object under your rigged geometry, make it a child of the joint.
