Activity › Forums › Adobe Premiere Pro › Constantly “Rendering Required Fields”
Posted by Jason Nower on December 15, 2011 at 6:59 pmHey All,
Ive been working on a project that uses alot of multicam. suddenly today it constantly is “rendering required feilds”, so much so it dosent even play at times. any suggestions?
Errol Lazare replied 13 years ago 3 Members · 4 Replies -
Max Frank
February 12, 2012 at 10:24 amHi,
I’m getting the same problem now.
Were you ever able to fix it? If so, do you mind sharing how?
Tx,
Wayne
Jason Nower
February 12, 2012 at 2:10 pmYou have to go to the initial sequence where you have
All of your multicam alligned. Go there and render the audio, that is where premier is getting caught up -
Errol Lazare
September 22, 2013 at 9:49 pmThis is an audio problem. Typically I cut the audio from the multicam sequence and paste it into the sequence where I nest the multi-camera sequence. A benefit to this is that you can adjust the audio without having to go back into the multi-cam sequence.
This problem also happens when you nest normal sequences into others. I have no idea why adobe is spending so much time in creating new features when they haven’t worked on making things better and more efficient for the features we already have. I innovating is more fun than trouble shooting.
Errol X. Lazare
EXL Films
http://www.exlfilms.com
