Activity › Forums › Apple Final Cut Pro Legacy › Constantly Losing Firewire Output!!! AGAIN………
  • Constantly Losing Firewire Output!!! AGAIN………
    Posted by Craig Ernst on November 5, 2005 at 6:25 pm
    I am constantly losing Firewire output. Anything will make this happen. I am constantly having to trash and rebuild FCP prefs. G5 or G4 whenever I switch anything in the easy setup (Kona card, BMD, etc.) when I go back to DV-NTSC there is no output via firewire. I can still capture through firewire, but no output. This has been happening for a while on both clean and dirty systems.
    Any advice???
    Craig
    Jerry Hofmann replied 20 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 6, 2005 at 3:15 pm
    Might try resetting the PMU button on those system’s logic board… Locations for this button are different from machine to machine, look in Apple’s online search in the support area for help here. Just search Power Management Unit…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
