Activity › Forums › Adobe After Effects Expressions › Constant XY motion expression
  • Constant XY motion expression
    Posted by Dustin Bremerkamp on September 1, 2016 at 7:22 pm
    Please reference the picture attached. I am trying to create a “web” like effect. I have seen this done in many other videos. Ideally, the dots will move in a random motion, and the lines are anchored and will follow. Instead of manually adding keyframes to each dot, I want to use an expression that will allow me to control the XY position of each dot. This movement must be random, so all the dots are not in sync. Also, I would like to be able to control the speed of the movement.
    Ive had no luck finding an expression that worlds. HELP!
    Thank you!
    Kalleheikki Kannisto replied 10 years, 1 month ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    September 2, 2016 at 6:19 pm
    Wiggle would work for what you describe, so unless you’re looking for something different than what you describe, use wiggle.
    Senior Graphic Designer
