Activity Forums Adobe After Effects constant stream of equidistant particles?
  • constant stream of equidistant particles?
    Posted by Scott Geersen on April 12, 2007 at 5:49 am
    another q:
    is there a workaround to get an emitter to emit a constant stream of particles? if for example i set particles per second to 10, then 10 come out, but not 1 every 10/25th of a second. or if i set to 25 particles per second, they don’t come out one per frame. if i need a stream of constant particles (for example, like on a conveyor belt) how can i achieve this?
    thanks,
    scott.
    Scott Geersen replied 19 years, 5 months ago 2 Members · 3 Replies
  • Scott Geersen
    oops! i thought i was still in the trapcode forum. apologies.
  • Steve Morris
    April 12, 2007 at 6:26 am
    I just tried it. It works for me. I set everything to 0.
    Use a Point, directional. “Velocity random” to 0, “velocity from” to 0
    There may have been another one that I did. The particles came out evenly spaced.
  • Scott Geersen
    April 12, 2007 at 8:04 am
    yes you’re right. i had assumed i needed velocity anyway and forgot that the particles on a motion path take their speed from the light defining the motion path.
