Activity Forums Adobe After Effects Expressions Constant speed Slow down
  • Constant speed Slow down
    Posted by Tudor Baican on January 15, 2023 at 3:00 pm
    Hello friends,
    I’m tying to add two interpolation functions with a smooth transition.
    The first part have a constant speed and goes from t=0 to t=1.
    The second part should be a slow down and stop function, from t=1 to t=2.
    I found out to create a custom exponential formula for part 2, but I don’t know to model the curve that speed of the start point match the speed of constant function.
    Do you have any ideas for that?
    Thanks.
    startVal = [100,100];
    endVal = [200,200];
    function easeX(startDur, endDur, startVal, endVal) {
    var x = linear(time, startDur, endDur, 0, 1);
    var c = 1-Math.pow(1-x,2)
    return linear(c, 0, 1, startVal, endVal);
    a = linear(time, 0, 1, startVal, endVal);
    b = easeX(1, 2, [0,0], [20,20]);
    a+b;
    Filip Vandueren replied 3 years, 8 months ago 4 Members · 4 Replies
  • Tomas Bumbulevičius
    January 16, 2023 at 8:03 am
    Hey Tudor, you are summing a+b at the end, in order to increase the endVal by additional 20?
    Also, there might be a clash at time value of 1, where neither of a/b will meet the condition.
  • Dan Ebberts
    January 16, 2023 at 9:48 pm
    I think maybe you just need to change the last part from this:
    a+b;
    to something like this:
    if (time < 1)
    else
    endVal + easeX(1, 2, [0,0], [20,20]);
  • Tudor Baican
    January 18, 2023 at 2:56 pm
    a+b;
    The a+b works fine. The problem is the start speed of b. The tangent of b at t=1 should be the same of a. Then b slows smooth down.
    I Think ;)??🤨
  • Filip Vandueren
    January 19, 2023 at 9:21 am
    Hi Tudor,
    it’s important to understand this key-point:
    you cannot control everything at once to get a constant speed slow down.
    I mean, you cannot define AND an arbitrary overshoot Distance (the extra [20,20]), AND a set time (1 extra second) AND a given starting speed (the amount travelled in the linear function) and make that result in a linear deceleration.
    At least 1 thing has to be set/precomputed to make the other 2 values work.
    For example, if you want the overshoot to be +[20,20], the time that needs to take for a linear deceleration from the given linear function is 0.4 seconds:
    b = easeX(1, 1.4, [0,0], [20,20]);
    should work perfectly.
    If on the other hand, you want the overshoot to last the full extra second, the overshoot distance needs to be [50,50];
    b = easeX(1, 2, [0,0], [50,50]);
    If you want to overshoot [20,20] and make that last 1 second, then the de-acceleration can’t be linear , and would need to be:
    var c = 1-Math.pow(1-x,5);
    etc.
    How to calculate these values:
    take this starting Point:
    startVal = [100,100]; endVal = [200,200];
    linearStartTime = 0; linearEndTime = 1;
    dampingCoefficient = 2; // 2 = linear deceleration
    overshootTime = 1;
    overshootAmount = 0.5;
    var c = 1-Math.pow(1-x, dampingCoefficient);
    a = linear(time, linearStartTime, linearEndTime, startVal, endVal);
    overshootVal = mul(sub(endVal, startVal), overshootAmount);
    b = easeX(linearEndTime, linearEndTime+overshootTime, [0,0], overshootVal);
    a+b;
    This will work for any startVal/endVal combination.
    But not when you change the length of the linearStartTime – linearEndTime.
    If you want the overshoot to still be 50% of what was travelled in the linear section, overshootTime would have to be calculated as:
    overshootTime = linearEndTime-linearStartTime;
    But 50% is rather a lot of overshoot, so how to calculate the values for 20% (as in your original example):
    overshootAmount = .2; // 20%
    overshootTime = (overshootAmount*dampingCoefficient)*(linearEndTime-linearStartTime);
    What if you want the overshootTime to be fixed to 1 second, and calculate the needed overshootAmount (thought this would be less realistic):
    overshootTime = 1;
    overshootAmount = overshootTime/(dampingCoefficient*(linearEndTime-linearStartTime));
