Activity › Forums › Maxon Cinema 4D › Constant Speed Rotation
  • Constant Speed Rotation
    Posted by Ciprian Darius on December 15, 2011 at 10:59 am
    Hello guys,
    I am having a small brain freeze in cinema4d r13 and I am hoping you guys can help me out.
    I have a cube and I want it to rotate, but not the regular “start slow-speed at middle-end slow” kind of rotation done by keyframing, I want to achieve a Constant Speed. I want it to start at a certain speed and continue at that speed forever. The point of doing this is that I want ultimately to make a .GIF file that will loop forever.
    If I can also get a suggestion on rotation-speed setting, that would be great. I would want my cube to rotate at the speed I want.
    How is this achieved? Xpresso? I am 100% sure this is possible, I just don’t know how. I am fairly new to cinema4d and the simplest approach would be best for me.
    Regards , Ciprian 🙂
    Ciprian Darius replied 14 years, 9 months ago 4 Members · 4 Replies
  • Randy Johnson
    December 15, 2011 at 4:39 pm
    If you want to keyframe a constant speed F-Curves need to be linear for that. Press spacebar in the timeline to start F curve mode. (looping is called cycling in the time line options.)
    To make a loop with expresso you just take a time node and have the output connected to the Rotation of your object to control the speed drop a math node between them.
    Time effecter in mograph does the same thing
    /Randy
  • Brian Jones
    December 15, 2011 at 9:04 pm
    you can also use Continue After in Timeline Functions/Track After
  • Adam Trachtenberg
    December 16, 2011 at 4:08 am
    Another method, if you have Mograph, is to use a Time effector in deformer mode (set to object).
  • Ciprian Darius
    December 16, 2011 at 10:49 am
    found a solution https://www.youtube.com/watch?v=trzqp6yyDzo
    Thank you for suggesting the FCurves randy johnson, that did the trick.
    Thank you to all for your help ^^
