Activity › Forums › Apple Final Cut Pro Legacy › Constant rendering..
  • Constant rendering..
    Posted by Martin Bisiker on December 9, 2009 at 1:31 pm
    Hi FCP’ers
    I’m editing a showreel on FCP 6 using H.264 files from different productions i’ve worked on.
    Is there a way to edit offline so i don’t have to continuously re-render every time i make a cut or add a new clip? Then i can just render the lot once when i’ve re-imported?
    Am i missing a trick?
    Cheers
    Martin
    David Bogie replied 16 years, 9 months ago 3 Members · 2 Replies
  • Zane Barker
    December 9, 2009 at 4:46 pm
    [Martin Bisiker] “I’m editing a showreel on FCP 6 using H.264”
    H.264 is NOT an editing codec. Convert them to a proper editing codec and you will not have the problem.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • David Bogie
    December 9, 2009 at 6:25 pm
    You cannot easily edit h.264 without huge hardware support, it’s a highly compressed streaming or constant playback release format but it requires intense calculations to build individual frames. If you want o avoid rendering you must transcode it to something that does not require constant rendering.
    bogiesan
