Activity Forums VEGAS Pro constant crashing
  • constant crashing
    Posted by Vlad Jensson on October 30, 2010 at 4:42 pm
    I currently am using Sony Vegas Pro 8
    I have spent 6 hours editing a music video and I have latle been having 2 problems.
    1. Vegas keeps crashing (usually when I open the project or when i try to play the project) it either freezes and waits to respond until i have to close it manually or it displays an error in which the program itself crashes. The error code presented is
    Sony Vegas Pro 8.0
    Version 8.0a (Build 179)
    Exception 0xC0000005 (access violation) READ:0xFFFF0008 IP:0x77AD1BB8
    In Module ‘ntdll.dll’ at Address 0x77A90000 + 0x41BB8
    Thread: VideoCache ID=0x1C3C Stack=0x755F000-0x7560000
    Registers:
    EAX=ffff0008 CS=001b EIP=77ad1bb8 EFLGS=00010246
    EBX=00000000 SS=0023 ESP=0755f160 EBP=0755f194
    ECX=00001c3c DS=0023 ESI=ffff0000 FS=003b
    EDX=77af5e74 ES=0023 EDI=62129074 GS=0000
    Bytes at CS:EIP:
    77AD1BB8: 83 38 00 74 06 50 E8 4E .8.t.P.N
    77AD1BC0: FF FF FF C7 45 FC FE FF ….E…
    Stack Dump:
    0755F160: 70C5BB5C 70B20000 + 13BB5C
    0755F164: 762EAE8D 762A0000 + 4AE8D (kernel32.dll)
    0755F168: 62125F58 61820000 + 905F58
    0755F16C: 762EA6B4 762A0000 + 4A6B4 (kernel32.dll)
    0755F170: 00000000
    0755F174: FFFF0000
    0755F178: C0000008
    0755F17C: 00000006
    0755F180: 0755ED78 07460000 + FED78
    0755F184: 0755FF78 07460000 + FFF78
    0755F188: 77A999FA 77A90000 + 99FA (ntdll.dll)
    0755F18C: 003E0CE0 003E0000 + CE0 (LVPrcInj.dll)
    0755F190: 00000000
    0755F194: 0755F1E8 07460000 + FF1E8
    0755F198: 5F698710 5F660000 + 38710 (wmvdecod.dll)
    0755F19C: 62129074 61820000 + 909074
    > 0755F1AC: 5F689214 5F660000 + 29214 (wmvdecod.dll)
    > 0755F1BC: 5F677F63 5F660000 + 17F63 (wmvdecod.dll)
    > 0755F1CC: 5F679635 5F660000 + 19635 (wmvdecod.dll)
    > 0755F1EC: 5F6796DE 5F660000 + 196DE (wmvdecod.dll)
    > 0755F1F8: 5F66B7C4 5F660000 + B7C4 (wmvdecod.dll)
    > 0755F21C: 5F671413 5F660000 + 11413 (wmvdecod.dll)
    > 0755F234: 00989680 00400000 + 589680 (vegas80.exe)
    0755F238: 3DFCB6B8 3DE40000 + 18B6B8
    0755F23C: 00000005
    0755F240: 00000000
    0755F244: 00000000
    > 0755F248: 71AC3418 71AB0000 + 13418 (WMVCore.DLL)
    > 0755F24C: 762E9A6A 762A0000 + 49A6A (kernel32.dll)
    > 0755F290: 73646976 73620000 + 26976 (msi.dll)
    > 0755F328: 71B58A99 71AB0000 + A8A99 (WMVCore.DLL)
    > 0755F364: 77C4B989 77C40000 + B989 (msvcrt.dll)
    > 0755F370: 71AB928C 71AB0000 + 928C (WMVCore.DLL)
    > 0755F380: 71ADAB64 71AB0000 + 2AB64 (WMVCore.DLL)
    > 0755F38C: 71AB928C 71AB0000 + 928C (WMVCore.DLL)
    > 0755F39C: 71C98F60 71AB0000 + 1E8F60 (WMVCore.DLL)
    > 0755F3AC: 71B58104 71AB0000 + A8104 (WMVCore.DLL)
    > 0755F3CC: 71B58111 71AB0000 + A8111 (WMVCore.DLL)
    > 0755F3D0: 004D0057 00400000 + D0057 (vegas80.exe)
    0755F3D4: 00330056 00240000 + F0056
    0755F3D8: 3E060000 3DE40000 + 220000
    0755F3DC: 1A7A614E 1A6D0000 + D614E
    0755F3E0: 0755F648 07460000 + FF648
    > 0755F3E4: 71B58215 71AB0000 + A8215 (WMVCore.DLL)
    > 0755F3F4: 71B5826B 71AB0000 + A826B (WMVCore.DLL)
    > 0755F400: 63646976 62FA0000 + 6A6976 (System.Windows.Forms.ni.dll)
    > 0755F414: 00630000 00400000 + 230000 (vegas80.exe)
    0755F418: 00000000
    > 0755F41C: 006F0000 00400000 + 2F0000 (vegas80.exe)
    > 0755F420: 0079006E 00400000 + 39006E (vegas80.exe)
    0755FFF0: 00000000
    0755FFF4: 00598AE0 00400000 + 198AE0 (vegas80.exe)
    0755FFF8: 00ADA7FC 00400000 + 6DA7FC (vegas80.exe)
    0755FFFC: 00000000
    Please explain what I could do to fix this issue.
    2. If my project ever does open some of the video files presented are red or black and nothing shows up on the preview screen.
    What do I do to fix this?
    John Rofrano replied 15 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    October 30, 2010 at 7:59 pm
    “Please explain what I could do to fix this issue.”
    For starters, upgrade to 8.0c as there were a lot of bug fixes since 8.0a that may resolve your problems.
  • Bill Mash
    October 30, 2010 at 9:59 pm
    I would uninstall 8.0a completely and download the upgrade to 8.0c.
    OS=XP=Yes then make sure your running service pack 3, if your not get there. I believe service pack 3 installs the latest version of NET Framework, if not do this as well.
    Uninstall Media Manager completely
    See thread below.
    https://forums.creativecow.net/thread/24/917944
    ~Just because you can doesn’t mean you should~
  • Vlad Jensson
    October 30, 2010 at 10:05 pm
    Im running on vista home premium 32 bit
  • John Rofrano
    October 31, 2010 at 12:27 am
    Did you update to Vegas Pro 8.0c as Mike suggested? Did that get you any further using 8.0c?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Vlad Jensson
    October 31, 2010 at 9:39 am
    Ok, now I have done multiple things, I reinstalled 8.0 and upgraded to c.
    I got vegas 10 and set my DEP settings to sony vegas.
    The programs no longer crash but now the problem is that my files wont render due to the fact that I dont have enough memory even though I am running on 3 gigabytes of ram.
    When I checked the cpu and memory usage of my computer it says that my computer was using 1.8 gigabytes of physical memory.
    I tried cacheing a usb but it did not help.
    Does this mean I should delete some files or just increase my RAM?
  • John Rofrano
    November 1, 2010 at 12:03 am
    [vlad jensson] “Does this mean I should delete some files or just increase my RAM?”
    Increasing your RAM will not help because you are using a 32-bit OS which can’t see more than 3GB of memory. You need to upgrade to a 64-bit OS and buy more RAM.
    ~jr
  • Shawn Van zyl
    November 1, 2010 at 10:30 am
    Hi
    I am having the same crashing problems, but im on Vegas 9d, my computer is set up as Etc:
    64Bit Windows 7
    8Gb DDR3 Ram
    2Gb DD5 Graphics Card
    I have edited est. 2min of footage from an Sony NX5 at 25FPS, the program is extremely slow, and when i get to about 2 min vegas 9d freezes and wont stop freezing, even after changing the ram usage under the preferences?
    This is extremely irritating, and limits my creativity in Vagas 9d to the max!
    PLEASE HELP
    PS: dont even try Canon 5D footage, it will never work!!
  • John Rofrano
    November 2, 2010 at 1:29 am
    [Shawn van Zyl] “I am having the same crashing problems, but im on Vegas 9d, my computer is set up as Etc:”
    Have you tried Vegas Pro 9.0e? The latest bug fixes are in 9.0e not 9.0d. It might or might not solve your problem.
    [Shawn van Zyl] “PS: dont even try Canon 5D footage, it will never work!!”
    From what I’ve read the Canon 5D footage works great with Vegas Pro 10. You should probably take a serious look at 10.0 if you are using a Canon 5D.
    ~jr
