Activity Forums Boris FX Particle Illusion Constant Crashes.
  • Constant Crashes.
    Posted by Rob Dahl on April 1, 2009 at 1:54 am
    I have just bought the complete version of Particle Illusion. I love what it can do. BUT… I constanly crashes:
    Windows VISTA or Windows 7:
    4 GIG on a Dell XPS 710
    Display Cards NVidia 8800 GPX (2 of them)& Newest Drivers loaded.
    2 30″ monitors (although I have the resolution now at 1920×1200 because PI doesn’t like 2560×1600.) OPEN GL is on.
    Scene: 3 layers:
    1) Background image
    2) Pro Emitter: Explosion (1)
    Deflector and blocker
    3) Chunk Explode (4 of them 15 frames apart)
    deflector and blocker
    You would think that a machine like this would just hum through the display. Even with trails turned off it gags and dies (locks up). Must kill it to close it and start over.
    Is there an optimum screen size to be working with this product?
    Getting slightly irritated… How do pro’s use this?
    Rob Dahl replied 17 years ago 2 Members · 2 Replies
  • Alan Lorence
    April 1, 2009 at 1:35 pm
    Try the same project file without the blockers and see if that stops the crashes.
    I’ve never run it at higher than 1920 x 1200, but there’s no limit in the code for that — it’s all about what your OpenGL drivers can do.
    If those drivers you’re using are beta drivers, try going back to the newest released (non-beta) drivers.
    Alan.
    http://www.wondertouch.com
  • Rob Dahl
    August 11, 2009 at 4:14 pm
    Alan,
    I forgot to respond to your post and beg forgiveness.
    I did reduce the size of the comp (and screen size) and yes it worked fine. While a simple solution, I needed some guidance. Thank you.
    Looking forward to your AE plugin… for I will use both!
    Rob
    Rob Dahl
    Transparent Alchemy
    Boulder City, NV 89005
    http://www.transparentalchemy.com
