Activity › Forums › Avid Media Composer › consolidating issues
  • consolidating issues
    Posted by Cesar Mendonca on May 5, 2015 at 7:46 pm
    Hi guys!
    Im trying to consolidate a sequence into a hard disk and i have no success with it.
    I manage to consolidate it into the internal drive however.
    I reckon that I have a problem with my drives but I don’t know how to fix them.
    It appears among my drives when I’m preparing to consolidate. I can select it and order consolidating.
    But as the process starts AVID starts loading file informations and then says
    Any suggestions?
    Thanx for the help!
    cesar
    MEndonca
    John Pale replied 11 years, 5 months ago 4 Members · 5 Replies
  • Andrew Kimery
    May 5, 2015 at 10:40 pm
    Do you have write access to the hard drive you are trying to consolidate to?
  • Cesar Mendonca
    May 6, 2015 at 11:07 am
    I do. Actually the problem goes deeper that this.
    Someone told me today that maybe the problem was that I was building the Avid MediaFile folder on my own and that I should let the computer do it.
    I just tried to do it: got a totally empty disk without any files on it; compressed on ExFat and with R/W permission and opened Avid. I went to Media Creation and just like before the only drive the program shows me is the internal drive of the computer.
    Any suggestions on what should I do to fix this?
    MEndonca
  • John Pale
    May 6, 2015 at 12:34 pm
    Try NTFS or Mac OS Extended. Not sure you can Consilidate to ExFat. I remember running into this in the past.
  • Ricky Barrow
    May 6, 2015 at 1:08 pm
    If you built on your own, make sure you name correctly: Avid MediaFiles\MXF\1
    ExFat works for us in RW but I haven’t actually tried to consolidate to it.
    Ricky
  • John Pale
    May 7, 2015 at 12:27 pm
    Yeah. Normal read and write …never had a problem, but I have had consolidating issues. It was awhile ago, the last I attempted it.
