Activity › Forums › Avid Media Composer › Consolidating “FAILED TO CONVERT TRACK TYPE TO DDEF”
  • Consolidating “FAILED TO CONVERT TRACK TYPE TO DDEF”
    Posted by Khoren Mirzakhanian on October 28, 2011 at 12:32 am
    Ran into a roadblock for the past two days now, hoping to find some answers.
    Been trying to Consolidate an hour long show to a new drive, with 30 frame handles (there are plenty of handles on the clips)
    I am not converting audio sample rate or bit depth or format.
    Just copying the media over to an external drive from Unity. I get the follow error.
    “Exception: Failed to convert track type to ddef”
    This happens about halfway through the consolidation. Everytime.
    So far I have tried to recreate the sequence, try different machines, consolidate to an internal SATA drive instead of an external, recreated database. Still no luck
    Any ideas?
    anyone?…bueller?
    Micke Mansson replied 12 years, 11 months ago 3 Members · 5 Replies
  • Kenny Krauss
    February 1, 2012 at 12:29 am
    Did you ever find a solution? I’m having the same problem and trying to find a solution quickly? Thanks much
  • Khoren Mirzakhanian
    February 1, 2012 at 12:50 am
    Yes I found the problem. In my case it was a bad media that needed to be digitized again. Same rule applies for imported media.
    To avoid re-digitizing and importing the whole show, I split it up my sequence into 4 acts, and made a new sequence for each act.
    Then consolidated them one by one, until i received the error message again.
    Then I started looking for a needle in a haystack. Meaning, lifting a clip either from the tail or head of the sequence, and consolidating. Lifting a clip and consolidating, until I would not get the error message. Then thats when I knew I had found the bad media/clip.
    Went back into my original 1 hour sequence, deleted the media for that one clip (do not do this if you do not have the original files/tapes)
    Consolidated one last time, and everything went through just fine.
    Once I digitized that tape that was causing all the trouble, I did another clean fresh consolidation, and got past the problem.
    It’s a days work, maybe two.
    Goodluck! hope this helps
  • Kenny Krauss
    February 1, 2012 at 10:14 pm
    Gotcha, thank you. We’ve isolated the “error’d” clips to try and find consistencies. Seems to all be from the same VT so we’ll try reimporting. Thanks so much. Very helpful!
  • Kenny Krauss
    February 1, 2012 at 10:15 pm
  • Micke Mansson
    October 15, 2013 at 11:43 am
    Hi.
    I’ve hade the same problem but after commiting all multicam tracks it all worked out fine.
