Activity Forums Avid Media Composer Consolidating a project
  • Consolidating a project
    Posted by Wojtek Bogdanowicz on March 29, 2006 at 2:34 pm
    Im running avid express 4.5 and Ive been asked to send an audio only OMF.
    My question is when I consolidate the project will it delete all the unused files?
    Is the best way of consolidating to first save project as version 2 then consolidate it so that the original project still has all the files?
    Geraint Pari huws replied 20 years, 5 months ago 3 Members · 3 Replies
  • Dave Schweitzer
    March 30, 2006 at 5:12 am
    Usually I do it this way:
    In your project,
    Duplicate the sequence and move it to a new bin, I usually name this bin CONS.
    Delete the video tracks and activate all the audio tracks. Select the sequence in the bin and then Export. In the settings, do OMF2, consolidate and embed media, and whatever other settings may apply to your audio person…transcode to sample rate, convert ot WAV or AIF, etcetera. You’ll need to pick the drive location to consolidate to, then pick the location and the name you’ll be saving the OMF file to.
    The Avid will then do its thing, and you’ll end up with one big file name.omf to give to the audio mixer.
    Once you hear the file worked for your audio person and they have what they need, open that CONS bin back up and you can safely delete everything in it – media included. Your original sequence with video will remain untouched and intact, ready for color correction, titles, letterboxing…
  • Wojtek Bogdanowicz
    March 30, 2006 at 11:08 am
    thanks for your help.
    will be trying it today
  • Geraint Pari huws
    March 30, 2006 at 1:14 pm
    always sensible to dupe the sequence first, if you want to consolidate before blowing an omf then the considate window should give you the option whether to delete origional media files or not, general best not to, you may find you’ve used media from within another project which you neeed to keep, best manually delete clips via the media tool or at bin level…
