Activity Forums Avid Media Composer Consolidate Subclip Mystery
  • Consolidate Subclip Mystery
    Posted by Berry Helfand on September 29, 2006 at 5:08 pm
    Hi:
    I haven’t had to do this in a while….so maybe someone can help.
    I’m trying to trim a master clip…and just save the subclip. As memory serves, i simply make the subclip…hit consolidate…then Avid will make a new master clip for that subclip. However, that’s not happening!
    When i consolidate…Media Composer creates a new file for the master clip as well…even though i didn’t highlight it!
    Can anyone solve this?
    Here’s my info. Media Composer v. 12.0.5 on OSX
    btw, when I consolidate i’m using the following options: “delete original file when done” checked, and “skip media files already on the target drive” unchecked
    many thanks.
    Berry Helfand
    Kandoo Films
    Berry Helfand replied 19 years, 7 months ago 4 Members · 4 Replies
  • John Pale
    September 30, 2006 at 4:59 am
    [Berry Helfand] “When i consolidate…Media Composer creates a new file for the master clip as well…even though i didn’t highlight it!”
    thats the way it works….you cant make a new subclip without a new consolidated master clip.
  • Michael Phillips
    September 30, 2006 at 3:59 pm
    Correct, every subclip must points back to a master clip – there cane be a one to one subclip to master clip or multiple subclips to one master clip.
    Michael
    anything 24fps
  • Michael Hancock
    September 30, 2006 at 5:35 pm
    This might be a hassle and not worth the time, but can’t you sublcip everything you want, then batch digitize the subclips? I haven’t tried it, and batch digitizing subclips might not work, but it’s worth a shot. Just choose one or two of your shorter clips and pop your tape in…you did bring these in with TC, right?
    Mike.
  • Berry Helfand
    October 3, 2006 at 8:51 pm
    thanks all for your feedback. I thought this might be a limitation of Avid. If anyone’s interested…here is my workaround:
    export the subclip…then import it as a master clip…then modify the timecode to match original footage.
    if anyone has a better way…asside from re-digging…let me know
