Activity › Forums › Avid Media Composer › Consolidate – original video quality?
  • Consolidate – original video quality?
    Posted by Eilat Ben-eliyahu on August 8, 2020 at 6:57 am
    Hello,
    I need to send AAF + original footage to the colorist who works on Davinci and lives in another country.
    Since it’s a documentary and the materials are quite large files, I would like to consolidate only those parts we used *and to keep the files in their original video format and codec*.
    When I open the consolidate dialogue in Avid 8 I see no mention of video settings.
    I’ve made a small test on a shorter timeline, and then compared the original file and the new .mxf file Avid has created by opening “Media Info” on both. The original file was shot on Sony FS7.
    Screenshot here: 14254_consolidatetesteilat.jpg.zip
    (I have other types of video in the project, too – some shot on Sony A6500, and some digitalized from VHS tapes).
    Since I’m not an expert with codecs and format, I can’t properly understand what I see in the Media Info.
    Would appreciate your help!
    Is it the same video format and the same quality? or did Avid re-encode it with different bitrate or different quality?
    Eilat
    Eric Santiago replied 6 years, 1 month ago 4 Members · 6 Replies
  • Pat Horridge
    August 9, 2020 at 8:33 am
    Consolidating in Avid has few options exactly because it doesn’t transcode the footage.
    You get the same codec wrapped in an MXF wrapper.
    Transcoding is where the codec and potentially quality can be adjusted.
    However not all sources can be consolidated. Avid will only consolidate content it supports.
    Its not normal to consolidate your sources as it can limit the graders options. Normally a list is made of all the sources used (no point sending source files not used in the edit)
    And those sources collected together and sent, in a drive if need be.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
    pat@vet.co.uk
  • Eilat Ben-eliyahu
    August 10, 2020 at 9:28 am
    Hi Pat,
    Thank you for the elaborated reply!
    I have very large files in my project. For example, the largest file is 100 GB of a 1-hour long conversation, from which we used only 2 minutes.
    I can’t see a reason not to consolidate it. If there’s no codec change, all the information will still be there – only the file will be 50 times smaller. How could it limit the grader’s options?
    Eilat
  • Pat Horridge
    August 10, 2020 at 9:37 am
    If Avid let’s you consolidate then it’s fine. The resultant file is identical in quality.
    I qualified it because Raw formats like Red and BM can’t be consolidated. And a transcode locks in choices that can’t be undo in that media later.
    Pat Horridge
    pat@vet.co.uk
  • Eilat Ben-eliyahu
    August 10, 2020 at 9:39 am
    Alright, I understand.
    Thank you so much! 🙂
  • Michael Phillips
    August 10, 2020 at 5:05 pm
    Referring to Pat’s comment about native RED R3D files not being able to be consolidated… while true, it is a shame that Avid has not updated its ability to do so as the SDK used in the AMA plug-in certainly allows for R3D files to be truncated to what is used + handles as new R3D files.
    Michael
  • Eric Santiago
    August 11, 2020 at 1:19 pm
    [Eilat Ben-Eliyahu] ” For example, the largest file is 100 GB of a 1-hour long conversation, from which we used only 2 minutes.”
    Yep ran into a few too many of those.
    I gave up on lugging around files like that.
    I make it a rule that if the used portion of something that large is less than 20%, then I start cutting it.
